hello to all. question on plt files and prm?
ironchef
I know about plt. That's for omega. But why does it make a copy in prm? Is their a way i can stop that? Or is it like a back up thing going on? I'm lost.
Tony Teveris
A PRM (parameter) file is created by GspPlot when you rip(output) to a device. It's a file that contains all your cutting/printing setup that you laid out in GspPlot.
If you reopen a PLT file with no changes and a PRM file exist GspPlot will use the setup defined in the PRM file, if the PLT file is newer then the parameter setup will be your GspPlot preferences.
ironchef
English please. Hahaha. I been using ga for years. Omega now for a year. But i don't speak computer. I went to college to be a chef.
Fred Weiss
You can delete the PRM but you may miss it the first time there's a repeat of the job and you have to setup all your profile and plot parameters again. It will save all the various setting in the GSPPlot program such as repeats, gaps, and the file names of any images that were ripped into the four process colors. Having the PRM file provides greater assurance that your print will look identical the second time to the first time.
The only valid reason to delete a PRM file is if it prints with a defect and you want a totally fresh outputting of the file. PRM files are automatically saved in the same folder as the PLT file.
