simpson246
Hi all, I was attempting to install the vinyl wrap onto my vauxhall astra front wing as a little test to get used to installing the vinyl.
It all started okay until I started getting little creases, to remove these, I lifted the vinyl. heated it and reapplied.
(Looking back, I don't think I should have done this, what do you think?
After this was done, what kept appearing was lots of little bumps which I believe has been caused from where the vinyl has been stretched from the heat. This then caused more marks and in the end, I gaves th up with it.
Is the trick not to use heat in this circumstance and only to use it when applying into groves, door handles etc?
What am I doing wrong to get these marks when squeegeeing and what should be done if they appear?
Vinyl used is : KPMF Airealise
Thanks,
Thanks,
