DerbyCitySignGuy
If you mean by 'stud mount' that you're putting some sort of projection on the back of the sign and then fitting these projections into holes punched into the surface then fine, the projections take the weight. But if you're not doing something like this then the sign still weighs what it weighs, perhaps more due to any projection you might have added. That being the case there is no way to 'redistribute' the weight of the sign. It still weighs what it weighs and all the weight, no matter how it's distributed is pushing down. To the floor. The only thing defying gravity is the tape.
I have no idea where this strike-through is coming form.Perhaps the typing gods are angry.
I don't think anybody is suggesting that studs magically make something weigh less. They do, however, reduce the forces acting on the adhesive, effectively increasing the tensile strength of said adhesive. By putting a stud into the wall, perpendicular to the sign, you ARE decreasing the effective weight of the sign. That's the ENTIRE point of stud mounts for signs.
If I had more time, I'd make a little drawing to express the concept, but you're turning the downward force of gravity into a diagonal force by adding the perpendicular stud, and reducing the shear weight on the tape. It's like a triangle of force.
(Edit: Also, on the right hand side of the formatting bar is a T with an x on the bottom right. That will remove all formatting from your text, including the strike through.)
