Need help badly. We have a Mutoh Ultima SC 1400D cutter. We are trying to print and contour cut 20" x 58" decals on Oralite 5650RA. We are using Onyx to print to our HP L25500 Latex printer. Onyx Cut Server to create a .plt file and Mutoh Cut Server to cut the .plt file. We are doing it this way because Onyx Cut Server has a bug that is causing a problem with our cutter. This workaround works great if I'm using white vinyl but the job calls for reflective vinyl. The Mutoh cutter can not read the marks or barcode on the reflective vinyl.
Things we've tried (without success):
We tried putting scotch tape on the reg marks and barcode.
We tried printing the same decal on white vinyl, cutting our the portions the cutter needs to read, and then laying that on top of the reflective decal.
We get an EPOS error after it tries and fails to find the registration marks. Onyx does not allow you to change the registration marks or barcode and Mutoh says we can not use a manual method with this cutter. HELP!! This job is for 60 of these decals for a bus company. Would really hate to lose it.
