doesn't that printer have a designated black print head, how many dampers feed the black?
if you let the damper hang, unplugged in to the head adapter, how long does it take before the ink recedes?
first take the damper off and make sure the o-ring is seated straight in the brass fitting. retighten, make sure when rotating the dampers toward the head adapter that you don't loosen the fittings.
