Help firing up an SP300V after a location and owner change?
Discussion in 'Roland' started by Xander388, Aug 18, 2013.
  1. Xander388
    Xander388 New Member
    6
    Here is the deal everyone. I bought a used SP300V. I am new to Rolands and somewhat new to printing. I am reading in the manual to install 2 cleaning cartridges and 2 dummy cartridges. I only received 1 dummy cartridge and didn't have any cleaning cartridges. I ordered 2 cleaning cartridges which should be here on Monday afternoon. The guy I bought it from did the cleaning cartridge flush out for moving in the back of the manual. What can I do to get it going now? Do I even need the cleaning cartridges at this point? Can I just install the inks and get it up and printing? I'm pretty lost.
    Any help and or advice would be greatly appreciated!
    Thanks,
    Jeff
  2. Speedsterbeast
    Speedsterbeast Active Member
    799
    4
    18
    Feb 1, 2010
    Thunder Bay
    You Can Try
    How long has it been since the printer was running?
  3. Jim Hill
    Jim Hill Active Member
    Test Print
    Go slowly setting up the printer and follow the manual and do everything it say's.
    Once you get to the point where you can do a test print that will tell you a great deal about the condition of your printer.
    Once you have a test print post the results so this site and then others will tell you what to do next.
    Did the person you purchased the printer from show you a test print before your bought the printer?
    Jim
  4. Xander388
    6
    Thanks for the help Speedster & Jim! The printer was running about a week ago. He went through the process at the end of the manual for moving. Yes, I did see it in action printing before I decided to purchase it. I will get my cleaning cartridges tomorrow and I will follow the start up manual to get it up and running. I will post back to let you guys know how things go. Hopefully I can figure out the versaworks and profiles etc.
    Thanks Again!
  5. Xander388
    6
    Everything is working real good now. I had to have the cleaning cartridges to get it going. Have learned a ton about these printers in the last few weeks.
    Thanks guys!
