Help I need to make a new sign look old and cracked
Discussion in 'Tips & Tricks' started by tdebruin, Jul 15, 2013.
  1. tdebruin
    tdebruin New Member
    3
    Jul 29, 2006
    Maine
    Can anyone tell me how to make a new sign on MDO have a crackle finish that will hold up outdoors on the back of a trailer. I did one with Hide Glue and it looked great but peeled and looks like junk 90 days after making it. I need to paint a logo on it and it has to look old and cracked. Any help would be greatly appreciated. Thanks
  2. Billct2
    Billct2 Major Contributor
    7,464
    642
    113
    Mar 12, 2005
    New England
    For a exterior distressed look I prefer to do a faux finish rather than actually using aging techniques. As you found out a lot of those techniques don't hold up outside
  3. Mosh
    Mosh Major Contributor
    5,809
    41
    48
    Oct 19, 2009
    Nerbaska
    print it...
  4. fresh
    fresh Very Active Member
    1,359
    124
    63
    May 16, 2011
    nj
    Are you painting this? If so, i've had really good results painting a few layers and then sanding them down. I haven't tried cracked paint, but that is because when paint is cracked, it starts peeling. i don't want my signs to peel.
    After you've sanded it down a little bit, you can use a stain to darken the wood.
    Good luck!
  5. Gino
    Gino Premium Subscriber
    33,338
    2,332
    113
    Jun 7, 2006
    PA
    Welcome from PA................................
  6. Circleville Signs
    Circleville Signs Very Active Member
    2,140
    11
    38
    Sep 30, 2009
    Circleville, OH
    Sanding, beating with a chain, spot clear coat, etc.
  7. Chriswagner92
    Chriswagner92 Member
    319
    19
    18
    Aug 26, 2013
    nc
    I actually just read an article about this, and did a few during my internship, except they were on actual wood planks. Basically paint the sign the base color, and before it is completely dry apply the vinyl paint mask. then paint the logo going with the strokes of the letters and what not so you could see your brushstrokes, peel the paint mask off before it is dry and then with scraps of vinyl touch the surface and peel up some "Grain". Sand lightly.
    Here is the link:
    http://www.signcraft.com/articles/20110614/How-to-make-a-vintage-Grocery-sign.aspx
  8. Supergirl
    Supergirl Member
    143
    Apr 8, 2013
    Chicago
    Thanks for sharing that! That IS pretty cool!
  9. Chriswagner92
    319
    19
    18
    Aug 26, 2013
    nc
