Help, Ink removal from floor
Discussion in 'Tips & Tricks' started by joelswork, Apr 16, 2010.
  1. joelswork
    joelswork Member
    137
    2
    18
    Jun 9, 2009
    Louisville
    Hey all, I am working on turning an old "American Greetings" card shop into a youth center now. We have several areas on the floor that have a buildup of ink that is up to 1/2" thick and will not scrap up. One of the guys tried a concrete grinder last night but the ink just plugged up the pores in the sanding stones:banghead::banghead::banghead:.
    My question is, what is the easiest way to remove this old caked on ink. Will a solvent work, if so...what?
    Thanks for everyones help!
    :U Rock:
  2. signage
    signage Major Contributor
    9,541
    82
    48
    Oct 5, 2005
    Penn
    What type of floor is it (ie. concrete, wood,laminate etc.)?
  3. joelswork
    joelswork Member
    137
    2
    18
    Jun 9, 2009
    Louisville
    Sorry about that, concrete floor. We are trying to prep it for painting right now.
  4. joelswork
    joelswork Member
    137
    2
    18
    Jun 9, 2009
    Louisville
    Thinking about a grinder
    I think I might try a 7" grinder with a wire cup brush, had to do that on some nasty floor adhesive left over from the 50's...worked good, just have this pesky cough for the past 10 years:rock-n-roll:
  5. Suz
    Suz Very Active Member
    1,027
    6
    38
    Apr 9, 2010
    The Great Northwest
    Not sure what the chemical content in the inks that you are trying to remove from your floor, but I'm assuming that the ink was used on a printing press since it was a greeting card business?
    I deal with printing inks, mostly just plastisol inks now which are used primarily in garment printing. However, I do use some commercial water base poster inks sometimes too, and I find those inks the most difficult to clean up out of all the inks that I commonly use.
    I love this stuff for removing really stubborn inks:
    http://www.texsourceonline.com/p-1348-franmar-greenway.aspx
    It's worth a try anyhow, if you want to avoid all the usual solvents. I like to spray it on the ink that needs to be removed and let it sit and soak in a while. Works like magic. Good luck!
  6. ridefst
    ridefst New Member
    16
    Oct 2, 2007
    Ohio
    How about an air chisel to scrape the ink off the concrete?
  7. joelswork
    joelswork Member
    137
    2
    18
    Jun 9, 2009
    Louisville
    thanks for all the advice, I'll start workin on it next week!
