Flatbed Tools
This is because so many ACMs are manufactured with different substrates and different chemical make-ups (different aluminum, different cores, different cutting equipment). Also, just because you have a (cheap Chinese endmill) doesn't mean all ACM cuts perfectly with that bit or has the longevity. Maybe I missed it, but what ACM are you using?Pardon if I say it, but I find it odd reading that anyone has a problem with routing ACM.
We use standard 2-flute cheap chinese 1/8" upcut end mills, and have for the last 14 years.
Our router is ancient, so we nurture it a bit, but 35mm/sec at full depth, single-pass, I can't recall having a problem. Just adjust spindle rpm as required.
If the top edge is looking a bit rough, get a new cutter. If you buy a pack of 10 for $5 or so, they're not an ordeal to toss out. If your edges are looking poor, maybe you got a bad batch of cutters?
I've also got expensive Onsrud cutters for high quality work, but ACM is about the easiest you'll get.
I leave the swarth in place to help hold the parts - we do not have a vacuum bed, and I tek-screw the sheet corners down to the MDF bed to secure the substrate.
Sent from my SM-G996U using Tapatalk
