Please send me a link to download the MSA version 4 for my VJ-1204,
altergroup2016@gmail.com
could I get these files?email me direct and I can send you a couple files that might help get you through the process....
Yes I have the MSM and I found the printer in the search of adding printer but in registration it gives "Printer Error 6" "The printer cannot be identified. Please check the followings. 1. Make sure that the activation mode is correct (PR)" and in printer the mode is board manager mode and there "waiting for command". And I have tried other modes in printer, but then it doesn't even show up in search. Is there any other mode in printer that could work or what does that "activation mode" mean.You can update the firmware with MSM (Mutoh Status Monitor). SM uses the same registration as the Mutoh Club. Go to mutoh.com>support>printer registration>(login)>application & manual OR Public FTP>MSM. You still need the login from Mutoh Club to install MSM. If you bought it used or whatever and need to create a registration, when the site informs you that the serial number has already been registered, just click through it.
