Have you gone through the control panel and told the printer to re-set the "Home Position"? To stop it from popping out, there is a piece of metal that needs to be bent slightly downward. You should be able to see it if you have the right-side cover off the printer.
I figured I would post an update. I still have not heard back from CMYK parts after multiple calls and emails. I got the home position fixed, and also ordered a new print head cable for the color head from Solvent Inkjet. The cable came in, and I installed it but I was still getting the same bad nozzle checks. So I called Solvent Inkjet to see if they had anymore ideas. I spoke to a very knowledgeable guy named Robert who told me several things to try, the last of which was removing the head and gently pushing cleaning fluid through it with a syringe to check and see what nozzles were open. When I tried that there were multiple nozzles missing from the cyan and magenta, which were the colors giving the worst test prints. I alternated between gently pushing fluid through the print head and also dipping it about 1/16" into a bowl of cleaning fluid and pulling fluid back through the head. It is now sitting just slightly submerged in cleaning fluid. In about another hour I will try to push/pull fluid through again and see if there is any change. So... correct me if I am wrong, but the fact that I can push cleaning fluid through and have multiple nozzles missing rules out and electronic problem correct? How can a new print head be "clogged"?
Also, a little side note just FYI: The people at Solvent Inkjet were nice enough to help try to diagnose the problem even though this color print head did not come from them. I did order some parts from them, but not the print head. Shipping on everything I have ordered from them has been very fast and all parts have been top quality. I am going to make a separate post in the appropriate forum about the positive interactions I have had with them, they are a great company to work with and go out of their way to try to help get your printer going again.
