Help needed.
MNT_Printhead
Working among the Corporate Lizard People
I don't. but it doesn't look like it would be too hard to remaking in AI after you fix the warping/perspective in PS.
Boudica
You could remake it in Photoshop then. Do you need the font because you need different numbers, or do you need to recreate that graphic?
Boudica
There's probably a member here that might know the font... Peeps that deal with mostly racing stuff. Numbers are notoriously difficult for the "find this font" by image searching aps, no matter how much you clean up the image. I'd trace the graphic of the numbers, and take it from there. or just find font that's close enough.
Patentagosse
You don't have Ai, not Ps either... are you a graphic designer? If you use Corel or any other signmaking softwares, you should be able to retrace it. By the look, it's mostly a cheap/free font as the structure is uneven...
