Help please!!1
Discussion in 'Summa' started by signrios, Sep 16, 2020.
  1. signrios
    signrios Active Member
    699
    3
    18
    Feb 26, 2007
    Rio Grande Valley
    here's my set up. printer surecolor s40600
    Onyx Rip
    cutter Summa d75
    here's my problem, im printing on the epson and trying to contour cut on the summa.
    i printed some sample decals with contour cutting on flexi and with a summa barcode.
    when i place the printed image on the cutter i get the message to set tool under barcode, which i do.
    the head moves left and right trying to read the barcode,
    but them i get a message that reads " unable to sense opos barcode"
    also, when using onyx serve-cut, when i send the file to the plotter serve-cut crashes and i have to restart it again. is this normal
    thanks
  2. balstestrat
    balstestrat Member
    213
    28
    28
    Aug 25, 2020
    Europe
    Don't run both production manager and cut server at the same time. That might be reason for your crashing.
    Is production manager saying at the bottom "Barcode server running"?
    Why do you use both onyx and flexi?
  3. signrios
    699
    3
    18
    Feb 26, 2007
    Rio Grande Valley
    flexi and cut server are not running at the same time,i have a rip computer only for onyx,
    thanks,
  4. iPrintStuff
    iPrintStuff Prints stuff
    958
    255
    63
    Sep 3, 2018
    United Kingdom
    What end of the barcode are you putting in? We had to get a patch from onyx once because our summa did NOT like the 6 end, but cut the 9 code fine.
  5. signrios
    699
    3
    18
    Feb 26, 2007
    Rio Grande Valley
    starting at the right side, i've tried the first line and middle lines and summa is not able to read them.
    thanks
  6. chester215
    chester215 Just call me Chester.
    376
    45
    28
    Sep 29, 2011
    Naugatuck, CT
    What version of flexi are you using and did it ever work or is this a new set up??
  7. signrios
    699
    3
    18
    Feb 26, 2007
    Rio Grande Valley
    completely new set up. i already have the summa installed on another computer, just nver used it to do contour cutting.
    thanks
  8. chester215
    376
    45
    28
    Sep 29, 2011
    Naugatuck, CT
    If it is a new setup, the dealer you bought the printer from should have set it up to contour cut prints.
    But in case you are running an older version of flexi that doesn't support the printer:
    We am running flexi 10 with the same printer. Both the printer and cutter are set up on the same computer.
    Since the version of flexi we are using doesn't have the drivers for the newer printer, we design in flexi with the contours not using the barcode function but the registration marks that are spaced on both sides of the print . Then exporting the file to a pdf and then importing the pdf print file into onyx rip-que and processing the file both printing and cutting from there.
    I do no think you can send a flexi file to onyx and expect it to work.
