Help Please - Need Smart Car Dimensions for Vehicle Wrap
Signs4Realtors
Can someone with the vehicle outlines file for the brand new Smart Car please email me the dimensions from front to back for the side of the vehicle. My outlines don't give me the 1/20th scale dimensions that I need to print the attached file to full scale. Email is info@951graffix.com Thanks!
Jester1167
I have ProVehicle Outlines and for the side I get H 59.86" x W 97.849 and back H 61.25 x W 61.682 (with mirrors - W 58.248 without mirrors)
phototec
So where did you get a Smart Car template that is NOT to scale (screen capture)?
:smile:
Signs4Realtors
Vehicle Outline Specs for Smart Car
Thanks very much for the dimensions. I set up my Adobe Illustrator file with a width of 97.849 and a height of 59.86 (see attached side view picture), but the top of the vehicle only comes up to 57.1". Why am I short by 2.76"? Side view looks very close to the dimensions, but I must be making a mistake on setting up the side view printable file. Any input is appreciated. Thanks! David info@951graffix.com
Jester1167
There are 3 major vehicle template makers. They hand draw their templates and each manufacturer ends up with a different size. That's why i called out which one i gave you. Your best bet would be to buy a template. Several of them sell single templates on line or go to your customers vehicle and take a few measurements.
phototec
:smile:
You did NOT answer the question above, you have NOT told us what template you are using?
Anyway, it's always BEST to use the WHEELBASE dimension to enlarge to, (center of one wheel to the center of the other wheel), and that is because different templates may be off. I always use the manufacture's wheel base dimensions, in this case the Smart Car has a 73.5" wheelbase.
:popcorn:
Signs4Realtors
:popcorn:
I am not using a template. The attached sample file is from the Exit Realty corporate group who outlines the specifications and design layout for their Smart Car vehicles that they encourage their franchises to lease/purchase. I am following their corporate design (but they only provide a .pdf, not the .ai vehicle outline file which I don't have for this vehicle). I hoped to simply enlarge their .pdf design to full-size (like I do with my typical vehicle wraps) but per the attached picture that isn't working out so easily. The wheelbase 73.5" suggestion is not even remotely matching up to the other suggested dimensions from Pro Vehicle Outlines. Any other suggestions are appreciated. I will most likely utilize my typical process of printing the initial design on cheap brown paper (like in the attached picture) to get everything aligned/spaced and then print on the 3M IJ-380. Thanks in advance for your input!
Signs4Realtors
Forgot sample attachment
Jester1167
If your going to be responsible for removal, i wouldn't use 380....
Templets are less than $25 and you've spent more than that in labor looking for a work around.
Signs4Realtors
Can you give me a suggestion on a website/link to get the template please. And what material should I use on one of these (e.g., IJ180?)
Signs4Realtors
That's an interesting way of doing it..... but I kinda feel like it's overkill. Trust me I'm super anal about making sure graphics line up and and fall in the right areas.... but that's what templates and pictures are for.
I just take pictures of the actual vehicle (or find online) and scale them, then overlay graphics to ensure sizing and placement is correct. I mean if printing the paper template helps you sleep at night that's fine....but seems like a lot of labor to me.
Just sayin!
It is overkill, but on my first few wraps that is how I have done them (and I shared my rookie method just for laughs). Learned from my carpenter dad to "measure twice and cut once". Since the brown paper is practically free and the 3M vinyl and laminate is expensive and in limited supply in my shop this method is a sure thing to line everything up. I have the Pro Vehicle Outlines disk, but it doesn't have all of the vehicles in it so sometimes I use other methods to make it work. Final product turned out great and I agree time is precious and it took a bit more time than it should of. Thanks!
Auburnpeanut
Private Message me the model of the smart car. I have a buddy who has one and if it is the same model, I will get some measurements for you.
Peanut
