Help Please
skyhigh
Ok I've searched the archieves for my problem. I've searched the help files from the software.... I've uninstalled and re-installed the solftware. I checked all cable connections.
NOTHING HELPS.
The cutter is not listed in program manager, but it does load up....then the error box.
Can anyone help me?
Fred Weiss
Have you installed or updated any software recently? If so, can you uninstall it to see if that helps?
Have you tried a Windows system restore?
skyhigh
just finished system restore. Everything was fine yesterday, so I backed up 2 days.
Here is a screen shot when I start to load the software (click ok) then it brings up the the error page.
The software won't open at all now.
Any thoughts Fred?
btw, I appreciate you jumping in so fast.
Fred Weiss
When you reinstalled your LXI, did you uninstall it first or did you just overwrite it? Nevermind ... I see your first post. Not sure what to suggest at this point.
skyhigh
just got done doing a current backup of my files. Although I'm under the gun with a couple jobs due monday, at least I'm good with that.
skyhigh
Where I'm at now.....
I UN-restored my computer back to today. Sign software opens, everything else seems to work just fine, except I'm back to the "Runtime Error" problem (see attachment) when I go to cut/open program manager.
Any other suggestions? Anyone?
WhiskeyDreamer
Professional Snow Ninja
not sure if it applies...but i know when i reinstalled my rip software for the DTG, i had to uninstall as well as go in and manually delete files before i could reinstall....did you check the uninstall directions to see if this could be the problem?
skyhigh
On a bright note....
I did receive the new "Victoria's Secret" catalog in the mail today:omg:
OK that was just a "bump", trying to mask my frustration. :frustrated:
Hi Fenris, yes I did go thru and clean up. Thanks for touching base though. :thumb:
