roland vp540Corrupted file or data.
Printer make?
Software?
File format?
Okay thank you for your help I will certainly give it a trySorry, apparently I need more coffee this morning. Missed the title which clearly stated you had a Roland.
If it's happening with every file, it's likely a data cable. Can you try swapping out your cat5 cable between printer and router/computer? If that doesn't change anything it will likely point to a cable inside the printer. I don't have much experience in that respect so hopefully someone else can provide some insight.
Sent from my SM-G920W8 using Tapatalk
No problem. Worth a shot to begin as it could be a simple fix
can be a printhead cable or flat cable from mainboard to printhead board, verify connections on printhead cables firstroland vp540
versaworks
it does it on all artwork
can be a printhead cable or flat cable from mainboard to printhead board, verify connections on printhead he
Thank you for replying to me, I don't suppose you know how I can do it?verify connections on printhead cables
