Help! Roland VS-640 Black ink streaking...
Discussion in 'Installation Equipment & Techniques' started by WrapYourCar, Apr 4, 2013.
  1. WrapYourCar
    WrapYourCar Member
    157
    40
    28
    Jun 28, 2012
    Melbourne, Australia
    Hi whenever i print a solid 100% Black background, it comes out streaking.. i've tried cleaning... but not much luck, do you think it could be the Cartridge or the head? it's a relatively new machine... under a year old. I have an urgent job i need to do tomorrow, the workaround might be me printing the black using a mix of colors... i really would like to print 100% K though.
    Any tips on how i can fix this would be greatly appreciated!!!
  2. WrapYourCar
    WrapYourCar Member
    157
    40
    28
    Jun 28, 2012
  3. mbarden
    mbarden Active Member
    596
    2
    18
    Oct 1, 2006
    Iowa
    Hello there WrapYourCar,
    We just solved this problem earlier this week. The VS Series introduced another encoder into the system. Everyone here is familiar with the linear encoder strip that all of out printers here use to control the print head carriage movements from right to left and back. The new encoder is a clear disc that controls the feed of the grit roller forwards and backwards. This disc is located in close proximity to the print head/caping station assembly. This means the disc gets some over spray and dust. Either remove your covers and clean the disc with some isopropyl alcohol or call and have a tech do it. DO NOT use the Roland cleaning fluid.
    This should get you back in shape.
    Mike B.
  4. WrapYourCar
    WrapYourCar Member
    157
    40
    28
    Jun 28, 2012
    Thanks Mike, was yours happening only with the "Black" ink? the other colors seem fine..
  5. J Hill Designs
    J Hill Designs Major Contributor
    15,549
    17
    do you print your black K only, or rich black (a mixture of CMY in there as well)? If K only, you probably have some missing nozzles on K head
    edit: just read it IS K only. I suggest 20/20/20/100 for rich blacks (others have slightly different formulas, but this one works for me) :thumb:
  6. ChicagoGraphics
    ChicagoGraphics Major Contributor
    4,847
    70
    48
    Feb 27, 2007
    World
    For a rich black C60%, M40%, Y40%, K100%
