Help! Tiling images?
Discussion in 'Corel' started by Kate Raap, Nov 9, 2004.
  1. Kate Raap
    Kate Raap New Member
    2
    i'm not sure if anyone can help me here or not. In my parents business I tend to do most of the dye-sublimation. I'm trying to do a wall tiling for outside of our office right now and I need to know the best way to do it. I can't seem to find any information on tiling inside of corel. I have Corel Suite version 12. I have a picture that I would like to blow up and then put on small 4X4 tiles and put together to make a mural but I'm totally stumped on how to do this. Any ideas out there? Thanks!
  2. Greg
    Greg Member
    169
    If you're talking about how to design it......If there's a quick way to tile I'm not aware of it, but I'd do this (perhaps its the hard way)
    Draw a 4 inch square, import your 4" graphic, use the POWERCLIP to put the graphic "inside" your square
    Draw your mural outline and duplicate your tiles
    Position your tiles to fill the mural
    Use the "Align and Distibute" command to get them perfectly spaced. I'd do one line across, Group, then duplicate the group. That way you're only ALIGNING LEFT and then Distributing toward the bottom
    Someone more familiar with dye-sub may have a better idea of what you're trying to do.....
    Are you trying to have One Big Image fill a bunch of tiles? Kinda like a jigsaw puzzle? Like this?
    [​IMG]
    If so, get all your tiles aligned, GROUP them, and then use the POWERCLIP tool to place your graphic into the tiles.
    Once you're done you can ungroup all of the tiles and the pieces of the graphic remain in the little squares.
