Help with cut issue
When I send a job with a countor cut everything always cut off consistantly to the left about a 1/16" - 1/8" of an inch. Is these any fine tune adjustment I can do to the cutter to moove the cut a little more to the right???
The whole x - y direction thing confuses me??? I know I gotta tune on in a little more. I'm just unsure which one it is???
bob
What you want is the 'Sensor Offset Adjustment' in your manual. This adjusts the logical distance from the sensor to the blade to conform to the physical distance of same. If it is not properly set contour cuts will be consistently off in one direction or another.
Y is the direction of carriage travel, X is the direction of media travel.
