Help with Perf cut on Graphtech FC-7000
Supergirl
Hi,
i watched Graphtec's video, and I can get it to perf cut my laminated printed vinyl, BUT the cut looks very rough. I'm using the cutting master 2 plugin for illustrator.
I read that people put transfer tape on the back and cut thru (not perf pattern) but i'm not sure i understand it right.
Also, how in the world do you make the backing paper split? never tried it, just curious :)
I'd appreciate any help with the perf cut techniques.
Thanks,
Tea
milchad
Hi,
Thanks,
Tea
I've tried to perf cut with the same cutter as you with limited success. It was a little rough around the edges and the cutting strip is getting a little worn. I'm in the process of upgrading to a Summa cutter and these issues will be a thing of the past.
You have to move the blade to the gap ahead of the cutting strip. Don't tear up your cutting strip lol
My settings for FC-8000 are Tool 3
cut line pattern on
up 0.8 mm
cut 20 mm
try that
Supergirl
I gave up on it :(
I print and cut, then just separate them all manually.
I assume that there are tools, but my volume wouldn't justify the purchase.
Good luck!
