tiredcreations
Working on a Ford E350 extended van. I laid it out for a horizontal seam close to the bottom. Normally I do vertical but after reading a bit I thought I'd give the horizontal seam a shot. My question is about getting the panels to line up exactly when installed. We need to install the bottom panel first so the top overlaps it, correct? I've always installed from the top down (without seams) pulling the backing paper off as I go & letting gravity help. Now, if I dry fit everything and install the bottom piece first, what are the chances that everything lines up again once the top piece is laid down? My thought is not very good with all the contours & creases in the van.
I don't do a lot of wrapping so I have a feeling I'm missing something.
