custom sign center
Does anyone have a 7000 series cutter running with Wasatch and willing to help me check some settings?
I've been posting a couple issues lately but I still need just a little help.
I replaced the Y motor and the plotter will cut fine in GPGL mode using Cutting Master 2 and CorelX6 (vinyl only).
I use Wasatch 7 with Mutoh VJ 1204 and the Graphtec Fc7000-130 for my print cut system and I also use Wasatch for just cutting vinyl so I don't have to switch between HPGL and GPGL modes. I took pictures of my settings prior to a factory reset and re-entered but I'm thinking I must have missed some stting when I took the pics.
Here's what happens when I send a cut file to the plotter:
For a print/cut file it reads the registration marks just fine but starts the cut about 12" to the left of where the orgin point is... so it's cutting 12" off.
When sending a cut only for vinyl it gets the data then advances the vinyl a little then stops.
The data is gettiing to the plotter but the plotter settings must need to be calibrated and I'm lost as to where to start. I've spent time with the manual but I'm getting nowhere. I've made sure I'm in HPGL when using Wasatch and GPGL when cutting with CM2.
I re-installed the driver for the plotter.
Here's a couple pics, hopefully someone will know something.
Thanks!
Thanks!
