Help with turning of automatic weed boxes in ONYX
infinite_mike
Hello, we are currently using ONYX v. 10.1 on a Mimaki JV33. Was just curious if anyone knew how to disable the automatic weed boxes that seem to happen when you select contour cut. Were using a Summa D160 if that helps out any. Thank you for the help in advance!
Bly
In the "marks" tab of job properties,
Deselect > Contour Cut Paths: Generate Tile Outline Cut Paths.
If it's coming up on all jobs you probably have it selected in one of your Quick Sets.
