Help! Won't Cut evenly
Discussion in 'Miscellaneous Plotters' started by ckelly617, Mar 19, 2006.
  1. ckelly617
    ckelly617 New Member
    19
    I have a Puma II and I am having problems cutting. It will cut correctly on one side of the cutter but when the blade moves to the opposite side it either cuts too hard or not enough. They aren't equal cuts from one side of the cutter to the other. Anyone else have any similar problems? What am I doing wrong?
    :help: -CK
  2. grafixhenk
    grafixhenk Member
    351
    Try to replace the blade / check the blade holder make sure it is clean( dust etc) Or if the cutter has a teflon strip replace it. Any of the above could solve your problem
  3. Signsforwhile
    Signsforwhile Very Active Member
    1,401
    Feb 17, 2006
    New York
    definetly sounds like the cutting strip.
  4. ckelly617
    19
    :thumb: Okay, don't laugh at me now. I've only had the machine 3 days. I put the teflon strip in the wrong spot. Oops! I put it in the right spot and guess what? It cut the same all the way across the sheet of vinyl. Thanks guys. Once again, you have come to my rescue. I was ready to take a hammer to it.
