Help !!!!!!!!!!
Discussion in 'Flexi' started by Jkovacic, Sep 4, 2006.
  1. Jkovacic
    Jkovacic Member
    41
    I am trying to move a file from coreal to flexi so that i can cut it, and when i export it and pull it up in flexi it puts nice little lines through it. and i also need to no how to change text into cures in flex so that it does not try to change the font thnks for any help Jason
    :peace!:
  2. The Big Squeegee
    The Big Squeegee Major Contributor
    4,954
    107
    63
    Oct 10, 2005
    Lawton, OK, USA
    Looks like you are having a panic attack.
    The lines may be from a problem with registration of the product. Make sure it is registered.
    In Corel you change the text to curves with Ctrl-q. I'm no help with flexi.
    Change it to curves in corel and save it as an EPS file. Flexi can import the EPS file. I think....:)
  3. Joseph Dunkle
    Joseph Dunkle Active Member
    518
    Was it like cutting the letters in half when you looked at the cut paths on the screen? It was doing that to me when I imported an Ai. file, it cuts them fine though.
    What I do is select all convert to curves in corel, export Ai. v7 and import into flexi
  4. Fred Weiss
    Fred Weiss Merchant Member
    20,542
    407
    83
    Sep 11, 2003
    Olympia, WA
    The segmented cuts has to do with the way Corel treats combined objects when exporting in EPS or AI. The workaround is to perform a "Break Apart" in Corel and then do a Path Sort - Automatic in Flexi after first converting the imported EPS to outlines.
    That may sound complicated but it just a couple of extra steps that are specific menu commands.
    And, yes, anytime you take text from one application to another you should always frist convert the text to outlines (paths in some applications). The exception would be when you are creating an Acrobat PDF.
  5. learned the hard way
    learned the hard way Active Member
    544
    If you have both programs loaded on the same computer, just pull up the file in Corel and then copy and paste into Flexi.
