Help!!!
ThumperH3
Hello, I hope someone will help me I'm using flexistarter and needing to know how to cut #'s with a 2" border of a different color? I have designed it in corel draw ,exported etc, both #'s cut the same size?????? :help:Any help will be greatly appreciated...
Goofball
You can always make your # and your border the same color for cutting purposes. That is what I usually do. Just pay attention weeding so you don't weed the wrong thing. Make sense? I know exactly what you are asking.....hope I answered it right.
Bob
Fred Weiss
Is your setup in Corel done with just vectors or did you use strokes to achiece the outlines? Did you convert everything to paths in Corel before exporting?
ThumperH3
I will try changing the color of the outline and see if
that works...I created the file in corel with text tool.... coverted to
curves ....copied ....pasted the added a 12 point outline to the back #
then grouped......exported...etc.
Thanks!:smile:
