Help
Discussion in 'Adobe' started by timandmikki, Mar 24, 2009.
  1. timandmikki
    timandmikki Member
    97
    I have a small problem that I was hoping someone here could help me out with. I am printing a logo for a local fire department. I designed the logo in Illustrator as a vector. The problem I am having is when I print it. There is a black fill in the back of the "shield". When I print, it looks like it is "frayed" and the black background goes on the graphic and letters in the design. I have tried to print it several times with the same outcome. Any ideas what I am doing wrong, or how I can fix the problem?:thankyou:
  2. UVchick
    UVchick Member
    40
    "Frayed" as in too thick of a black ink laydown and it's bleeding into rest of graphic?
    What mtl are you printing on?
  3. Rodi
    Rodi Very Active Member
    1,333
    1
    38
    Aug 3, 2007
    Did you meticulously check your layers to make sure its not the ai file?
  4. timandmikki
    timandmikki Member
    97
    material
    I tried it both on gloss and matte solvent printable material. I printed two examples. One with yellow lettering and a red helmet in the center, and one with white letters and the read helmet. On the white letters, it did not bleed into it, but still did on the helmet. On the yellow letters, it did it both on the letters and the helmet.
  5. timandmikki
    timandmikki Member
    97
    file
    I opened it in photoshop and tried flattening the image and saving it as a JPEG. I then printed from there.
  6. timandmikki
    timandmikki Member
    97
    Ideas?
    Anyone how I can cure this?
  7. UVchick
    UVchick Member
    40
    Have you tried adjusting your heat settings?
    Try adjusting your ink limits.
    Also what is your black's cmyk values, 100K or a composite black?
  8. timandmikki
    timandmikki Member
    97
    black
    Its at 100K. Should I up my heat?
