High Intensity/Diamond Grade Reflective
Discussion in 'Vinyl' started by klemgraphics, Jan 27, 2010.
  1. klemgraphics
    klemgraphics Active Member
    624
    Jan 13, 2008
    Midwest
    I have a fire dept wanting to put high intensity reflective on the rear of one of their trucks and they need it to be cut into diamond shapes in order to apply it to a diamond tread surface. They said they have seen it cut into the diamond shapes before at fire aparatus shows and it is crazy expensive. Like $10 for a 1" x12" strip of diamonds.
    I'm looking at 3M 4000 Diamond Grade and I am wondering how this stuff will cut, of if it even will cut on my FC-7000?
    Anyone have any experience with this?
  2. Mosh
    Mosh Major Contributor
    5,809
    41
    48
    Oct 19, 2009
    Nerbaska
    Get you checkbook out. That stuff is a pain to work with as well. You are going to try and put in on diamond plate?
    Tell them to get it from the people at the show, I think you have to by this stuff by the roll anyway.
  3. letterman7
    letterman7 Very Active Member
    1,271
    86
    48
    Nov 10, 2008
    Pennsylvania
    Well... all the trucks in this area have single sheet reflective right over their diamondplate. It's not the 3930/4000 diamond grade, just the 6800/6801 conformable reflective. Seems to suit them just fine, as their chevron stripes are laid over the base color. I've never tried to lay the sheeting over diamond plate, but I would assume it's pretty much like laying over rivets - a pain in the butt, so charge accordingly. Show them the different grades and price tiers and let them make the decision.
  4. gabagoo
    gabagoo Major Contributor
    5,732
    106
    63
    Oct 10, 2006
    Vaughan, Ontario
    WARNING!!!! DANGER!!!!!! You gonna possibly do damage to your blades. The only machine I know for cutting diamond grade or honeycomb reflective is the Allan Datagraph with the built in heat sealer. Without the sealing I think moisture gets in between the clear and the reflective and will look mouldy over time.
  5. Bizzarth
    Bizzarth Member
    55
    Check out scenedots.com.
  6. Zambookajoe
    Zambookajoe Member
    254
    1
    18
    Jan 11, 2009
    Ontario Canada
    www.securitrim.com Try these guys they sell exactly what you want just did the local fire department. but it aint cheap 12x12 sheets will go roughly for 5$ a sheet but they are cut already
  7. klemgraphics
    624
    Jan 13, 2008
    Midwest
    I think I will try to turn them away from the diamond grade since price is of some concern and I won't be able to cut it correctly anyway. Anyone know if you can get flourescent yellow reflective and where to get some from if it is?
    Guess I won't be able to cut circles out of reflective anyway seeing as though scenedots has a patent on them...:ROFLMAO:
    Thanks for all the help, I love this site and how helpful everyone here is!
  8. letterman7
    1,271
    86
    48
    Nov 10, 2008
    Pennsylvania
    There is no flourescent reflective. It's either yellow or it's not. Two colors of yellow available through multiple suppliers.
  9. klemgraphics
    624
    Jan 13, 2008
    Midwest
    The 3M diamond grade has a flourescent yellow so I didn't know if it may be available in a standard reflective, I didn't think so since I couldn't find it anywhere though.
  10. Mosh
    5,809
    41
    48
    Oct 19, 2009
    Nerbaska
    Reflective yellow is pretty bright!
  11. Dzrt1st
    Dzrt1st Member
    204
    Jan 22, 2008
  12. letterman7
    1,271
    86
    48
    Nov 10, 2008
    Pennsylvania
  13. digitalwoodshop
    digitalwoodshop Member
    173
    Apr 9, 2008
    One option is to ask Grimco if they can die cut it? They have a vendor that die cuts 4 inch white engineering grade for application to Engineering Grade Blue or Green 911 signs that I buy from them.
    I have a FC 7000 too but find it easier sometimes to keep a stock of Grimco stamped letters as I make 911 signs at Craft Shows I do in season. Cash and Carry... Wally Mart has a plastic box for Thread with 4 x 4 inch slots that the letters fit in for a great storage.
    I use the Electro Cut blue and green translucent over Grimco High Intensity White 911 sign blanks for the townships that require High Intensity.
    AL
  14. digitalwoodshop
    173
    Apr 9, 2008
    Called Grimco and die cut high intensity is a no go..... sorry....
    AL
  15. klemgraphics
    624
    Jan 13, 2008
    Midwest
    I talked them into just going with Oracal's Lemon Yellow Engineering Grade as they didn't want to pay the price of the high intensity anyway. We're going to be doing something similar to the scencdots but with a maltese cross shape instead of circles.
    Thanks for all the ideas
  16. Mosh
    5,809
    41
    48
    Oct 19, 2009
    Nerbaska
    Our State Patrol uses HI refelective so all the local agencies that I service wanted to go to it too, until they found out how much it was. Some even claimed I was out of line on the price until they checked Gall's and other's prices. They all still use me AND normal reflective films on stuff.
  17. mshi
    mshi New Member
    20
    There are some guys ot there that will wholesale for you, I know some guys that have a die cut becasue of the difficulty and constant replacement of blades.
  18. Malkin
    Malkin Very Active Member
    2,188
    16
    38
    Feb 11, 2009
    Augusta, ME
