The way a hologram works means that any overlamination will reduce the holographic effect (its micro ridges so they get covered by the laminate)
Theoretically a liquid lamination might be able to do it, but probably won't.
Usually holograms are applied after lamination via hot pressing with a holographic shim hence why you can get clear holograms because it's an embossing effect.
