it will cut a depth that is always through the vinyl then it will go up and down and just perforante the paper for easy "popping" them out.hey, thanks brushmarks... I always thought that was just for cutting the media off the roll, like the "Material Cut" feature on the printer. Since we usually have more managable sized sections by the time we run our cuts, I've never used it.
So, what is a proper setting for halfcut going to do, cut through the vinyl and score the paper , but not cut it? It doesn't pounce or perf though right?
^^^^^^does it register off the same marks as a regular cut?yes
So you program 2 cut files for one print? NO regular setting
when I send a print and cut file, both go to production manager (in Flexi) at once, and after printing I can line up reg marks & send the cut. If I have a second cut, how do I define it as a seperate job that waits until I manually move the knife & "set" the halfcut? no it is your normal cut
Do I create those cuts as a seperate job to output after moving the blade? No
If so, how do I associate the previous print-based reg marks, to the second job?
send your regular cut you have set up.I've got my halfcut turned on but i just don't know what to do from there
it is on your cutter it self just like a pen plot when u design for pen plot it is the same as for cut it is just a SETTINGi don't have half cut set up in my software. We use cut server for contour cutting.
