How do I create . . .
Replicator
Is there a proper method for creating a dreamy/hazy look around the edges of a photo in Photoshop.
I have never learned this technique before and don't know where to begin.
Or is there a filter or plug-in that will accomplish this effect ?
Fred Weiss
Check in layer effects for glow and then play with the transparency of it.
SignosaurusRex
You can always close your eyes, click your heels and say three times......
Sorry Marc.....I could not resist.:ROFLMAO::Big Laugh:wink:
acothran
I'm not 100% sure of your idea of haze/dreamy but I would almost take it as a white vignette (see pics). For this effect:
1. Chose Elliptical Marquee Tool (EMT)
2. Set Feather to 150px (may vary for image size but a good place to start)
3. Create a new layer
4. Drag the EMT crosshairs from the top left corner to the bottom right corner
5. Select inverse (CTRL-SHIFT-I or CMND-SHIFT-I)
6. Fill with white
7. Lower the layer opacity (example below is 54%)
Don't know if this is your idea of hazy but I thought I would put it out there. If you do the same steps but fill with black, you get a nice vignette.
Allen
Replicator
6. Fill with white
Allen
You Rock . . . Thank You !
that was extremely good and detailed instruction that worked perfectly . . .
I appreciate the tutorial !
acothran
Replicator - Thanks. I'm on here ever day but don't post a lot because I'm still a newbie. A good friend shared that PS "trick" with me and I use it a lot. You can try different colors, different feather sizes, and the size of your elliptical to create many different looks. You can also use that elliptical marquee tool & select inverse on the main layer or duplicate layer, to put some effects (distort, blur, glow, etc) on the outer edges. Glad I could help.
Allen
beermonster
i'll drink to that!:beer
get in the habit of doing non-destructive affects - learn how to create stuff with layers so it remains editable for tweaks etc
or just drink lots and squint a bit:clapping:
