How Do I Do this!? Complex Illustrator Layer Question.
Discussion in 'Adobe' started by cptcorn, Mar 4, 2010.
  1. cptcorn
    cptcorn adad
    1,210
    2
    36
    Jul 16, 2007
    Two Harbors
    I have an illustrator file that is moderately complex. I need all paths, objects, etc in their own layer. They are currently all contained in the same layer. Is there a fast way of doing this without clicking and dragging each piece to its own layer?
  2. Rick
    Rick Certified Enneadecagon Designer
    6,955
    389
    83
    Apr 17, 2003
    Valle Vista
    Select the objects, Go to your "layers" palette, go to your options menu on the upper right corner of the window, "RELEASE TO LAYERS" (SEQUENCE)
  3. cptcorn
    cptcorn adad
    1,210
    2
    36
    Jul 16, 2007
    Two Harbors
    EEEEEEEEEEEEEEEEEEEEE!!! (in a little girl's voice)
    You are my new Super Friend x 4,823 layers!
  4. luggnut
    luggnut Very Active Member
    does release to layers do it? i'm just guessing as i have never done it but i think in the layers pallet there is a release to layers command that does?
    ooops i see rick has already answered
  5. GAC05
    GAC05 Major Contributor
    5,931
    790
    113
    Dec 27, 2005
    Guam USA
    Nice, I like that one.
  6. tanneji
    tanneji Member
    497
    that's flippin handy! Thanks!!
  7. B-RAD Graphics
    B-RAD Graphics Member
    243
    :thumb:
  8. visualeyez
    visualeyez Member
    431
    23
    18
    Jan 23, 2007
    harbor
    On most files: Select all, then go to the Object drop down, and select Clipping mask, then release. You might have to do this multiple times. I also like to then create an object with no fill or stroke. Select this object and then go to the Select drop down, and select Same, Fill and Stroke. You can delete all this junk out of the file. Some files with clipped images and gradients require more work.
