How do I turn off cuts with a one color print job?
I am trying to print and cut some decals on a matt black vinyl. I imported the illustrator file no problem and set up the white foil where I need it. I want to outline of the decal to be cut but nothing else inside.
Example, the file is the outline of a car, there is a license plate with numbers in it and a back window with lettering in it. I'm able to get the white to print exactly how I want and keep the lettering by filling the lettering using a clear fill. I've selected the window, license plate and all text and selected turn off cuts but when I send it to the plotter it is still cutting everything...
Any suggestions?
I'm using Omega 3.0... perhaps I need to check the illy file because I may have the outline colors set to CutContour and that may be overiding everything I am trying to do...
I'll check that out.
