How do I...
Discussion in 'Summa' started by Deaton Design, May 31, 2007.
  1. Deaton Design
    Deaton Design Very Active Member
    1,602
    2
    ...keep my D60 from rolling out too much material. Id rather the dang thing just start cutting instead of rolling out ten feet of material before it does.
    Anyone?
  2. DRPSignsNGrafix
    DRPSignsNGrafix Very Active Member
    1,449
    What software are you using? Check settings.
  3. Mike Paul
    Mike Paul Major Contributor
    5,437
    8
    38
    Dec 30, 2003
    NJ
    (In Flexi) Put a check in the optimize cutting order box under your advanced tab and keep it at apx 12in.
    Make sure you don't have any pre-feed setting selected.
  4. Gino
    Gino Premium Subscriber
    32,242
    2,002
    113
    Jun 7, 2006
    PA
    Do you have some sort of 'Form Feed' box that you can check or uncheck ??
  5. Goofball
    Goofball Member
    204
    John.....I've always hated that about my D60 too....so aggrivating. Can't wait to see how to fix it. Good question!!!
    Bob
  6. Ruddbow
    Ruddbow Member
    320
    Mar 15, 2006
    Central Iowa
    sensors
    turn media sensors off. I think it's an option directly on the plotter settings.
  7. SAS
    SAS Active Member
    611
    Aug 23, 2005
    My T-750 dose that also, but I think it's a good thing so you can make sure it is going to track ok before you starts cutting.
  8. PMG
    PMG Very Active Member
    2,453
    Ya beat me to it...........I agree !!!!!!!!!!!!!!!!!!!!!!
  9. grafxxx
    grafxxx Very Active Member
    1,015
    1
    38
    May 15, 2007
    watertown ma.
    sas and pmg are right on. that is the best feature.
  10. OldPaint
    OldPaint Major Contributor
    dont your cut program have a PRINT PREVIEW? corel does.....and showes ya where your objects to be cut lay on the cut sheet.
    i have rolands so know nothing bout d-60, but if you dont have the text/object to be cut sittin on the very beging of the cutting page.....it will do what yours does.
  11. dswanson
    dswanson Member
    231
    we were told that the reason that it does this is to roll material off of the roll so that there is less continuous strain that could possibly cause material to not feed at the rate it should
