How do you add color to a vector image in flexi
Discussion in 'Flexi' started by signdesign, Mar 25, 2005.
  1. signdesign
    signdesign Member
    151
    I am driving myself crazy. For some reason I can put a color back ground in or color any - Its kind of like a badge with a banner across it. But I can't insert any color. Its just a line vector. Help please
  2. Dennis Raap
    Dennis Raap Active Member
    586
    Oct 5, 2003
    USA
    Make sure that the vector is a closed loop other wise all that will happen is that the line color will change.
  3. signdesign
    signdesign Member
    151
    what do you mean by a closed loop.
  4. Dennis Raap
    586
    Oct 5, 2003
    USA
    Did you create the object in Flexi or was it imported? If it was created in Flexi it will most likely it will be a closed object if it was imported sometimes the line around the object will have an opening in it if there is an opening you will not be able to fill the object.
    Also make sure that Flexi is set to view as a filled object.
    What version of Flexi are you using?
  5. signdesign
    signdesign Member
    151
    Its flexi 7 - Its is defiantly a closed object. Where do you set to view as a filled object
  6. Dennis Raap
    586
    Oct 5, 2003
    USA
    Look under View it is the top listing.
  7. signdesign
    signdesign Member
    151
    I tried that it only changes the line from black to what ever color i pick. I need to color inside the box. ?
  8. Dennis Raap
    586
    Oct 5, 2003
    USA
    On your Fill/Stroke Editor look for the the tab with a paint bucket and make sure that the box for Wireframe is not checked when the object is selected.
  9. signdesign
    signdesign Member
    151
    I tried that but it wont fill in any color
  10. Dennis Raap
    586
    Oct 5, 2003
    USA
    Under the Fill/Stroke Editor is it set to Solid fill?
  11. southpawP8NTR
    southpawP8NTR Member
    299
    Jan 24, 2005
    Potosi, MO
    If you created this object yourself try using the "Select Point Tool" encompass the object to highlight the "points" then go back to the "Select Point Tool" drag out the other options in the menu and select join paths option and encompass the entire object again with this tool.
  12. signdesign
    signdesign Member
    151
    yes it is
  13. Dennis Raap
    586
    Oct 5, 2003
    USA
    Running out of ideas can you email me the file?
  14. signdesign
    signdesign Member
    151
    think i am figuring it out. Let me try a few more things and see what is going on. But thank you for all your help. Is there a book or cds about tips and tricks for flexi
  15. Dennis Raap
    586
    Oct 5, 2003
    USA
