How do you do halftones in Fpro7.6?
Discussion in 'Flexi' started by Gene@mpls, Aug 23, 2006.
  1. Gene@mpls
    Gene@mpls Very Active Member
    1,982
    82
    48
    Jun 17, 2003
    Blaine, Mn
    I use 7.6v2 to setup .eps files for printing- I actually rip with softrip. There
    must be a way to set a halftone??? I hope. There is a 'shade' selector in
    Fill editor- gradient fills- advanced- but it is always grayed out. Thanks Gene
  2. myronb
    myronb Active Member
    763
    Gene, If I understand what you want to do.....select the 'button' with one red dot, Then 'shade' box will then be available. then you just adjust the percentage that you want.
  3. Gene@mpls
    1,982
    82
    48
    Jun 17, 2003
    Blaine, Mn
    Thanks Myron- I figured it out- in color mixer you can select 'spot' color
    and set the halftone. Thanks for your reply. Gene
  4. RiXaX
    RiXaX Member
    223
    Aug 17, 2004
    Mendocino, CA
    What about when you want the shade tones to be in a dot pattern?
    Is there a way to adjust the size and density of the dots?
  5. Mike Paul
    Mike Paul Major Contributor
    5,437
    8
    38
    Dec 30, 2003
    NJ
    You have to go into your advanced settings/screen and lower the Line frequency.
  6. RiXaX
    RiXaX Member
    223
    Aug 17, 2004
    Mendocino, CA
    Mike, Could you please slow it down a bit more for me. Is this the Advanced button in Fill/Stroke Editor? I don't see anything there for Line Frequency. When I go to Color Spec's, I don't see anything there about line frequency either. I appreciate the help.
  7. Mike Paul
    5,437
    8
    38
    Dec 30, 2003
    NJ
    You have to open Production Manager and go to Rip & Print. Then go to the advanced tab> Click on screen> and lower the line frequency there. Lower LPI = larger size dots and less banding on thermal printers.
  8. RiXaX
    RiXaX Member
    223
    Aug 17, 2004
    Mendocino, CA
    Mike, I don't have a digital printer to set up for a profile. I want to print on transparency film from an HP Deskjet. I's still not dialing this one in yet.
