How do you pull TWO control points off a node?
SignProPlus-Chip
Trying to tweak a custom shape and I cannot seem to generate a second control point off the node so I can round a point in both directions.
Anyone?
Auburnpeanut
In flexi, both line segments on either side of the point have to be a curve for you to be able to pull a control on either side. If one side is a curve and one is a straight line then you will only be able to adjust the curve from one side of the point. Once you change both sides to a curve, you can adjust the curve as a cusp, smooth or symmetric.
Hope it helps!
Peanut
Fred Weiss
For future reference, at least in the terminology as I learned it, a node and a control point are the same thing. The arm that extends out from a node to control the length and angle of a curve is called a control handle.
