How do you remove the Battery on the Motherboard
Discussion in 'Mimaki' started by badouali, Jun 2, 2011.
  1. badouali
    badouali Member
    43
    Jul 25, 2010
    The Gambia West Africa
    HI. Can anyone give me tips on how to remove the battery on the motherboard of the JV3 250sp. I have already removed the Firewire board. But i dont have a clue on how to remove the battery. Thanks
  2. Locals Find!
    Locals Find! Very Active Member
    2,732
    1
    36
    Oct 17, 2010
    Fort Myers
    are you referring to the bios battery?
  3. badouali
    badouali Member
    43
    Jul 25, 2010
    Yes please. The one behind the firewire board located at the motherboard.
  4. Locals Find!
    2,732
    1
    36
    Oct 17, 2010
    Fort Myers
    On my pc you just power everything down. Unplug. Hold the power on button for 20 seconds to drain any residual power left over. Then simply pluck it out.
    If its not that easy for your system I would check your motherboards manufacturer site for a manual. That would probably have more detailed instructions then my basic ones.
  5. badouali
    badouali Member
    43
    Jul 25, 2010
    Not PC. I mean the actual Mimaki JV3 250sp. I am not talking about pc.
  6. Locals Find!
    2,732
    1
    36
    Oct 17, 2010
    Fort Myers
    The methods on any motherboard are going to be the same. If you can't just pull it out you need to read the manual for the board.
  7. badouali
    badouali Member
    43
    Jul 25, 2010
    I dont have the manual,thats why i came online to ask for help.
  8. macmedia
    macmedia Member
    49
    Why do you want to remove the battery?? If you do that and remove the power going to the board, you're going to lose your settings and have to reprogram everything (lots of work and time). There shouldn't be any normal reason for you to do so.
  9. the battery should slide out . not pop put. i assume you trying to reset the memory to use expired inks?
