Hi,
Instructions for using refilled or compatible cartridges are in the user manual.
If you decide to use refilled cartridges or non-HP cartridges, you will need to follow these
instructions for the printer to use a cartridge that it considers empty.
1. Install the cartridge in the printer (see Replacing an ink cartridge
on page 56).
2. The front panel will indicate that the cartridge is empty and the cartridge removal process will begin.
cartridge. Press the Cancel key to stop this automatic process.
3. On the front panel, select the icon.
4. Check the Replace ink cartridges option, but do not select it.
5. Simultaneously press and hold the Cancel key and the up arrow key.
for at least two seconds.
6. A series of warning messages will be displayed on the front panel. To reply to each message,
press the Cancel key to abort the process, or the Select key to confirm that you want to
continue.
When you have pressed Select in response to all prompts, on the front panel
the status of the regular ink cartridge will appear, but the refilled or non-HP cartridge
will appear as empty with a warning sign
Good luck
