SignMeUpGraphics
Super Active Member
Hi all,
Drawing a bit of a blank here as it's not something we do regularly, but we need to add some bleed and contour cut line to a small design we've been provided by a client. Since there is a drop shadow, adding a couple of mm of bleed and adding a cut line isn't as easy as first thought. Any ideas on how to do this and achieve a somewhat accurate representation of the original artwork? I have a preference for 2mm bleed to allow for variances between print and cut, but the shadows and corners make it more difficult than normal. I hope I'm just tired and missing something simple. We use Illustrator have have vector/PDF artwork.
