How to Change the Number of Rollers Used on a Graphtec Cutting Pro FC7000-160
Discussion in 'Graphtec' started by gamerxr72, May 28, 2009.
  1. gamerxr72
    gamerxr72 Member
    42
    When I started using our FC7000 I noticed that we only ever used three pinch rollers but saw the fourth and thought to myself, "The more the merrier".
    The process for changing the number of pinch rollers the machine recognizes is complicated, and I typed it out as the technician explained it to me on the phone. I figured I'd post that process here for others with the same problem.
    GRAPHTEC CUTTING PRO FC7000-160
    How to Change the Number of Pinch Rollers Used
    1. turn off machine
    2. hold enter+test and have someone else turn the machine on, unless you have long arms
    3. press menu and go to background settings
    4. press next until you see select suffix on the f4 key
    5. under select suffix change it from STD to AKD then press enter
    6. turn the machine off and back on
    7. press menu and go to background settings
    8. press next until you see a setting to adjust the number of pinch rollers
    9. change it to either 3 or 4 and press enter
    10. turn the machine off
    11. hold enter+test and have someone else turn the machine on
    12. press menu and go to background settings
    13. press next until you see select suffix on the f4 key
    14. under select suffix change it from AKD to STD then press enter
    15. turn the machine off and back on
    16. thats all!
