how to color fill a prismatic font
Discussion in 'Fonts and Typography' started by Zardoz_Canada, Oct 20, 2005.
  1. Zardoz_Canada
    Zardoz_Canada Member
    43
    I feel dumb having to ask this but I just can't seem to figure it out.
    I have recently purchased a few of Dan Antonelli's prismatic fonts. I have no problem in coreldraw inserting color fills or a gradient fill in the black areas of the fonts but I just can't figure out how to do a fill for the white area.
    As you can see on this link http://www.signdna.com/v2/cart/category.php?id=62&gp=46 on the 'alka' sign a gradient fill has been applied to the white area of the corinne font.
    How does a guy pull that off? I guess I could convert it to a bitmap but then I loose all the ability to play around with the size and the ability to edit the text.
    :thankyou:
    Colin
  2. Cadmn
    Cadmn Very Active Member
    2,859
    colin I'm just guessing as I've never played with prismatic fonts but might the areas be grouped with something else or behind something else I had trouble changing colors once & realized later it had 2 pieces & one was on top the other I deleted it & viola. Good luck hope I helped but as stated shooting in dark here
  3. geb
    geb Very Active Member
    1,847
    4
    38
    Apr 23, 2003
    Adirondacks
    Colin, when you select your font, convert it to curves, then under the "arrange" drop down at the top select break apart, now you can change all your colors by selecting, or sweep selecting, an area you want to change.
    Maybe there's an easier or quicker way, but this is how I've done it in the past.
    George
  4. Zardoz_Canada
    43
    i broke apart the font & then selected break curves apart. it allowed me to color all the text but an unfortunate by-product is that it seems to fill in the hole in the center of the font. For example: the center holes in the 'a' are not their anymore.
    Any ideas?
  5. iSign
    iSign Major Contributor
    13,027
    31
    48
    Nov 29, 2003
    Kahului, Maui
    copy your text to the clipboard, then the one copy still on your work space will be modified to allow the "second color" to be filled on it... then the "copy" will be pasted back.
    The original have "holes in it"... not just the hole in an "o" for example... but all the white halves of the prismatic look are holes, so your original will be pasted back as is... but first the copy on the screen needs to have all the prismatic vectors deleted... but being careful not to delete the needed contours for the normal holes in letters like "O".
    I use the white selection tool in illustrator because it allows me to select these vectors without uncombining anything... then when done, they display properly without combining again... but lots of ways will work. Paint these with the second color, & past back the original right on top so the "holes" show through to the second color.
  6. Steve C.
    Steve C. Very Active Member
    3,278
    3
    Chiseled or Prismatic fonts are usually two part fonts. Is yours only a one part font? Maybe you are using a combined version. You should have a base font and a chisel font that fit one over the other so that colors can be changed. I am pretty sure Dan Antonelli's fonts are all two part fonts.
    Hope Fred won't mind if I offer this link...it may be of some help.
    http://artandsignstudio.com/tutorialchisel.html
    Steve C.
  7. Baz
    Baz Very Active Member
    I have those fonts and they are "Compounded objects" like an "O" or "P" etc.
    What you need to do is convert your type to curves, uncompound all of the letters (your holes in the middle of compounded shapes will turn to black).
    For all your compounded letters you will have to select the inside and outside of the shape and "compound" them back. this will leave all the chiseled objects ungrouped. Select them all and group them up for easy manipulation.
    Hope i didnt confuse anyone :glasses:
  8. Jen Goodwin
    Jen Goodwin Active Member
    868
    Dec 17, 2003
    Maine
    :Big Laugh Yeah, totally what Baz said. :Big Laugh
  9. HSG
    HSG Guest
    Are you trying to change the direction of the fill?
    HSG
