Click to Support Signs101 ...
Wow, We do thousands of 3165 with 210 stickers and never set the cut pressure above 90 / the perf pressure above 200. Sounds like you need to run the blade out further or see if your blade tip is snapped off.
tip is fine, blade is extended more than double the vinyl thickness... i think i am going to bring in the blade in and slow the speed down... i believe i am at 30/cm right now.
