how to cut signatures?
ba1980
First of all, I'm still new to sign making and haven't had much experience at cutting things which weren't already made.
I've got a small job coming up and they want some signatures cut. How would I go about this after I get them scanned in?
I tried to import them into Photoshop CS2 and make a path out of it, then save it as an illustrator file, then import that into Flexi, but it says it doesn't have anything to cut.
grafxxx
just import them into flexi and vectorize it .the other thing is that they might have to be thicker for you to cut them. i used use a sharpie and trace the sig them scan it in
Fred Weiss
If you make a path of it in Photoshop you then must export the paths to Illustrator. All of which is kind of the long way around since you say you have FlexiSign.
Just scan straight into Flexi and then autotrace it there.
ba1980
You guys are a lifesaver as it was making me mad trying to do the path way. And they are already signing with a sharpie :).
gabagoo
thats exactly what we do, make sure they sign there name on a full 8.5 x 11 so you can scan and reduce
Sign_Boy
You can also add a bit of a gaussian blur or median effect to help clean up the edges. This way they aren't so node crazy.
On a side note if the scan is not that dark "Black" convert the image to grey scale and adjust the color balance so it is black. Then do the above.
ba1980
I don't have a gaussian blur effect in flexi. I only have blur. I tried blur and couldn't tell it helped clean up the edges any.
