How to do die-cut on foamboard?
Discussion in 'New Member Introductions' started by razak, Oct 13, 2006.
  1. razak
    razak New Member
    5
    Hi there....I need some tips on how to die-cut on
    foamboard? Hope you guys could assist me.
    Razak / Singapore
  2. Bigdawg
    Bigdawg Just Me
    7,459
    133
    63
    Jun 8, 2005
    Sunny Florida
    by hand with a knife... we just did a half dozen "dancing couples" on coroplast that I had to cut out by hand (what a pain!!!) but if you have knife skills then foamboard would be a lot easier.
    Now if you are talking lettering... well good luck with that :smile: I don't know of any way to diecut it and it would be a nightmare to try to cut out exactly. Maybe someone else has a trick for it...
  3. GB2
    GB2 Very Active Member
    1,916
    80
    48
    Nov 15, 2005
    Connecticut, USA
    Router
  4. razak
    razak New Member
    5
    Thanks Ms Stacy J i appreciate that.
  5. The Big Squeegee
    The Big Squeegee Major Contributor
    4,954
    107
    63
    Oct 10, 2005
    Lawton, OK, USA
    Welcome from Oklahoma!
    :Welcome: to :signs101: I use a Knife.​
  6. Alot depends on the cutter you have. Some machines will cut on rigid media, which can give you an outline to trace with your knife. This is how I die cut my magnetic signs (i.e ribbons, scrolls etc)
    The cutter cuts about halfway through the medis and I finish it off with a good knife.
    If your cutter does not cut rigid material, the it's the old fasioned way like the rest of us.
  7. SignMan Sez
    SignMan Sez Member
    246
    I've used a knife blade made for a jigsaw with success.
