how to get red to be red with my value jet
Discussion in 'Mutoh' started by shirtsource, May 4, 2007.
  1. shirtsource
    shirtsource Member
    45
    I recently purchased a value jet and when I print the reds look more like a mixture between red and orange. Can anyone tell what I am doing wrong or point me in the right directions. Thanks in advance.
    Brian Grogan
    Shirt Source
  2. high impact
    high impact Very Active Member
    Change or use the correct monitor profile and click on soft proof under the view tab so you see your reds correctly.
  3. Replicator
    Replicator Major Contributor
    10,230
    9
    38
    Nov 19, 2006
    Sun City, AZ
    I had the same problems with my roland and discovered that experimentation
    with ICC profiles for certain media types and adjusting ink limit density was the
    key to success in getting the reds I needed . . .
    The profiles were much different for every media type !
    Good Luck !
  4. Compilla
    Compilla Active Member
    733
    Make sure the rendering intents on Vector ,text & gradient are set to no color correction and use a CMYK color mixed instead of RGB.
  5. Arstron
    Arstron Member
    134
    Also check your temp settings on your machine, I had the problem with red and other colors until I noticed the temp settings was set to the minimum when I received it.
  6. ChicagoGraphics
    ChicagoGraphics Major Contributor
    4,770
    53
    48
    Feb 27, 2007
    World
    Invest in colour management software
