Need Help How to line a roll of mesh for printing?
Discussion in 'Product and Supplier Referrals' started by Dukenukem117, Sep 19, 2018.
  1. Dukenukem117
    Dukenukem117 Member
    193
    7
    18
    Sep 4, 2018
    Fountain Valley
    I need to print on a mesh material that does not have a liner. What type of service or vendor am I looking for who can apply a liner? The handful of prints I've contracted out were lined manually, which made it too expensive. I need a service that can line an entire 100' roll of this material for feeding into a roll-to-roll printer.
  2. SignMeUpGraphics
    SignMeUpGraphics Very Active Member
    1,467
    325
    83
    Apr 11, 2012
    Australia
    Can you elaborate on why you need to print on bare mesh, then line it afterwards?
    I can't see the use case for this.
  3. unclebun
    unclebun Very Active Member
    The liner needs to be applied before printing so he doesn't ink up his printer.
  4. flyplainsdrifta
    flyplainsdrifta Active Member
    585
    116
    43
    Oct 13, 2017
    ct
    either you need a printer with a setup to accommodate ink overspray and blow thru, like one of the newer hp latex machines, or bite the bullet and get pre lined mesh. I've never heard of someone only applying backer to existing mesh, especially if it is not their own product. sorry man
    • Agree Agree x 1
  5. Solventinkjet
    Solventinkjet DIY Printer Fixing Guide
    4,376
    830
    113
    Aug 2, 2011
    Denver, CO
    I've always used the pre-lined mesh but could you possibly tape down some butcher paper to the platen of the printer and run it like that and then just throw the paper out at the end?
  6. Joe House
    Joe House Active Member
    993
    222
    43
    Feb 5, 2004
    WA
    I'm usually agreeing with you VanderJ, but this seems like it would just make a mess on the back of the mesh which would just get dragged forward on the printer and make a bigger mess.
    • Agree Agree x 1
  7. AKwrapguy
    AKwrapguy Active Member
    969
    281
    63
    Sep 6, 2014
    Anchorage, AK
    So I would probably get stuff that already has a liner in it. As far as manually doing it..... In theory if your were able to take some thin, lo-tack temp vinyl you could use a laminator to apply it to the back and than roll it back onto a tube and send through the machine. This would increase the material thickness so you would have to accommodate for that. Heat would also be an issue as the vinyl might get to warm and stick to the printer. No idea what issues the ink would cause on the adhesive, but I'm sure it wouldn't be awesome. There would probably be some other unforeseen issues as well depending on your setup.
    You might want to reach out to a manufacture that already creates backed mesh banner and see if they will sell you just the backing. This would be your best bet if you have to do it this way.
    Depending on the job it might just be better to outsource it till you can figure it out.
  8. Dukenukem117
    Dukenukem117 Member
    193
    7
    18
    Sep 4, 2018
    Fountain Valley
    We need to print on a very specific mesh that doesn't come pre-lined unfortunately as it wasn't originally made for printing. But we are introducing a new product (we are not a printing company) that requires this particular mesh, and it does print well so long as you can overcome the mesh issue.
    We thought about lining it ourselves with kraft paper, but I was hoping there were readily available professional services that offered this.
  9. bannertime
    bannertime Very Active Member
    2,160
    505
    113
    Sep 8, 2016
    No
    I think if I had to do this. I'd probably use a laminator and some type of tacky paper for the lining. Treat it like any other lamination process.
    • Agree Agree x 2
  10. GAC05
    GAC05 Major Contributor
    6,112
    894
    113
    Dec 27, 2005
    Guam USA
    Maybe get away with some medium tack premask as a liner - shouldn't be too hard to set with a laminator.
    • Agree Agree x 1
  11. Dukenukem117
    Dukenukem117 Member
    193
    7
    18
    Sep 4, 2018
    Fountain Valley
    I'm looking at the Aplitapes from RTAPE for this purpose. When I think laminator, I think the plastic envelope that you use to encase copy paper for cheat sheets and study guides. Is that what you are referring to?
  12. SignMeUpGraphics
    1,467
    325
    83
    Apr 11, 2012
    Australia
    Wow, if that's what you're thinking of when talking about industrial printing you should reconsider this project...
    • Like Like x 2
