Need Help How to make plate not see through
Discussion in 'Gerber' started by nssignguy, Jun 4, 2020.
  1. nssignguy
    nssignguy New Member
    13
    Jul 19, 2017
    Nova Scotia
    Hi,
    I make a 3/16" thick polycarbonate plate with an Edge 10mil lexedge black background with white text overlay laid down on top with adhesive, then the cutouts are routered out. They backlight this so the text is lighted up to see in the dark and the issue is that light gets through the black and ruins the look of the panel. My question is how to stop this and make the black less opaque but still see the white text. I was wondering if there are any Gerber foils that are less see through, surprisingly the black lets quite a bit of light through? Or if this doesn't work I was thinking about using black vinyl on the back and then cutting out slots for the text, but this adds cost and is a pain.
    Any ideas would be appreciated.
  2. signage
    signage Major Contributor
    10,699
    291
    83
    Oct 5, 2005
    Penn
    Use regular vinyl and cutout the lettering. If you had looked into creating double sided gerber prints you would have seen recommendations to print with either background silver background, usually 3 hits will stop most light. in your situation I would have tested if I want the gerber print to stop the light form a lit box.
  3. nssignguy
    13
    Jul 19, 2017
    Nova Scotia
    Thanks for the info, will give it a try.
  4. Jester1167
    Jester1167 Premium Subscriber
    you need to use translucent black if you want to block out the light. regular black vinyl will typically have a mottled appearance.
  5. Jburns
    Jburns Active Member
    835
    163
    43
    Jan 19, 2009
    Denver
    Do they still make the jet black foil, or a foil that was used for making screen negatives?
