bob
Knowing what to charge is every bit as much a part of being in this business as being able to do the work.
Blindly relying on someone else's algorithm to price your goods means you're not fully competent to be in the business. There's nothing wrong with using an algorithm to produce prices if and only if you understand exactly how it works and you really don't need it, it's just handy.
You should be able to generate a price all by yourself and, if you have some system or another, this system merely should confirm the price you manually produced.
Most packages available are far too detailed and thus produce way too much variation in price for what is fundamentally the same product. Estimate is probably the worst in this regard.
