how to print a transparent lens?
Discussion in 'Flexi' started by chad17, Feb 2, 2009.
  1. chad17
    chad17 Member
    112
    1
    18
    Dec 30, 2008
    Mississippi
    how do i print this out? i have a transparent lens on an object on the top of my work, when i print it out it turns that object all the way black has no transperancy left.
  2. Fred Weiss
    Fred Weiss Merchant Member
    20,928
    551
    113
    Sep 11, 2003
    Olympia, WA
    What software are you asking about? If Flexi, you need to read up on using masks.
  3. zmatalucci
    zmatalucci Very Active Member
    flatten the image
  4. chad17
    chad17 Member
    112
    1
    18
    Dec 30, 2008
    Mississippi
    yeah talking about flexi, okay so it should be under masks in the manual/
  5. zmatalucci
    you can still flatten it. copy it, paste it, rasterize it, print it.
    you still have the original
    Easy as pie
  6. Sign Works
    Sign Works Very Active Member
    1,552
    67
    48
    Nov 25, 2006
    Sacramento, CA
    They print just fine for me on my Versacamm, no image flattening just export file as .eps then open file in RIP and print away.
  7. Jackpine
    Jackpine Major Contributor
    I do the same but on a Mutoh. From Corel I export as an .eps file and print as always.
